11 years agoattribute 'event usage within procedure
Hi, I'm having a procedure (non-synthesizable code) and I am trying to use the 'event attribute on a signal declared as input to the procedure: procedure priority_req(signal tb_cont...
11 years agothats because the 'event attribute is not a signal, and hence cannot be waited on.
instead, use: wait on tb_control.command;
