11 years agoattribute 'event usage within procedure
Hi, I'm having a procedure (non-synthesizable code) and I am trying to use the 'event attribute on a signal declared as input to the procedure: procedure priority_req(signal tb_cont...
11 years ago@Tricky
thank you, the compiler is happy with "wait on". Is "wait on signal" accomplished on assignment of signal or value change?
