11 years agoattribute 'event usage within procedure
Hi, I'm having a procedure (non-synthesizable code) and I am trying to use the 'event attribute on a signal declared as input to the procedure: procedure priority_req(signal tb_cont...
11 years agoI am using HDL Designer flow and the error I initially mentioned occurs in the "Generation step" of the ModelSim TCL flow.
With the proposed 'transaction attribute the tool passes the generation step but triggeres a compile error in ModelSim:wait on tb_control.command'transaction; tb_control is a record containing a signal "command" ModelSim error:
Attribute "transaction" may not be read from formal signal parameter "tb_control".
VHDL Compiler exiting It seems that various tools interpret these attributes differently: 1. ModelSim accepts 'event, HDL Designer doesn't 2. HDL Designer accepts 'transaction, ModelSim doesn't
