EBoln
6 years agoArria V clock no output dependent(15610)
HI!
i am using arria v for a new project but ran into the following behavior: - when I only use logic, the clock pin is synthesized successfully - when I add video ip core to the project, then al...
- 6 years ago
Found a bug in my custom qsys module, the reset was confused
JonWay_altera
6 years agoHi EBoln,
There is no attachment. If your project is huge, could you send us a simplified design that shows the problem. Thanks.
- EBoln6 years ago
- JonWay_altera6 years ago
Thanks @EBoln for sharing the root cause of the problem.
