array value miss of add
When we used the command line to simulate our project, these files did not run normally, causing the output variable 'Hdl_out' during simulation to produce erroneous results that were not in line with our expected design. This variable came from the ADD output module of the previous level. The `Subsystem_org.v` file is set in the unlock file for the test. In order to reproduce the problem in the future, we have attached the required source files to the submission materials. We hope this can help you find and solve this problem.
- ShengN_altera
I had compiled successfully all the files and testbench straight away in simulator. I notice there're undefined (xx) problem with the previous variables already attached screenshot. Since most of the signals are inter-related, probably have to check back which function signals output cause the conflict.
Sheng
- ShengN_altera
Do you have any further update or concern on this thread?
Sheng
