yelen
2 years agoarray value miss of add
When we used the command line to simulate our project, these files did not run normally, causing the output variable 'Hdl_out' during simulation to produce erroneous results that were not in line wit...
ShengN_altera
2 years agoHi,
I had compiled successfully all the files and testbench straight away in simulator. I notice there're undefined (xx) problem with the previous variables already attached screenshot. Since most of the signals are inter-related, probably have to check back which function signals output cause the conflict.
Sheng
