Agilex 7 F-tile PCIe questa simulation failed
You might want to check that the above is not due some earlier error (it says Errors: 2), search for Error from the top rather than from the bottom, or you can grep for all the Error in your simulation log file and leave out all the zero errors:
grep Error your-simulation-log-file | grep -v 'Errors: 0'
- tthhuang2 years ago
Hizutalors,
Thanks for suggestion, but I have check the log, all the two errors are listed below.
** Note: (vsim-3812) Design is being optimized...
# ** Warning: (vopt-10587) Some optimizations are turned off because the +acc switch is in effect. This will cause your simulation to run slowly. Please use -access/-debug to maintain needed visibility.
# ** Error: ../../../../ip/pcie_ed/pcie_ed_syspll_inst/systemclk_f_300/sim/pcie_ed_syspll_inst_systemclk_f_300_p45yqwy.sv(1432): Module 'ctfb_avmm1_soft_logic' is not defined.
# For instance 'avmm1_ena_inst' at path 'pcie_ed_tb.pcie_ed.syspll_inst.syspll_inst.x_sip'
# ** Error: ../../../../pcie_ed_rp/ip/pcie_top/syspll/systemclk_f_300/sim/syspll_systemclk_f_300_p45yqwy.sv(1432): Module 'ctfb_avmm1_soft_logic' is not defined.
# For instance 'avmm1_ena_inst' at path 'pcie_ed_tb.dut_pcie_tb_ip.dut_pcie_tb.g_bfm.p_dut_ep.altpcietb_bfm_top_rp.g_bfm.u1.rp.inst.dut.syspll_inst.systemclk_f_inst.x_sip'
# Optimization failed
# ** Note: (vsim-12126) Error and warning message counts have been restored: Errors=2, Warnings=1.
# Error loading design
# End time: 16:40:36 on Apr 25,2024, Elapsed time: 0:01:58
# Errors: 2, Warnings: 1, Suppressed Errors: 2- Wincent_Altera2 years ago
I am able to go through the simulation after clean up the environment,
Can you please try it again ?
If not you may try our golden pcie example design through link below
https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/agilex/agf027-and-agf023.html
Regards,Wincent_Intel
Hi Wchiah,
Yes, it works now, thanks for your help.
Best regards
Victor
