mschiller-nrao
2 years agoAgile X Transciever Design (JESD204C + F-tile) HSSI_PLD_ADAPT_RX_CLUSTER error
How do I correct this error? I do not believe I'm constraining this device as it's in the Auto Tiles. Error(14566): The Fitter cannot place 1 periphery component(s) due to conflicts with existing...
- 2 years ago
So turns out if I use an external clock for my IOPLL the problem is resolved.
Dotted line is the configuration in the project above resulting in the error, solid line for userclk (reference to IOPLL) from another FPGA pin works fine:
Harshx
2 years agoHi,
Your design is failing at Design analysis.
Error message:
VHDL error at memory_loader_pkg.vhd(124): file 'f_in' is not open
