mschiller-nrao
2 years agoAgile X Transciever Design (JESD204C + F-tile) HSSI_PLD_ADAPT_RX_CLUSTER error
How do I correct this error? I do not believe I'm constraining this device as it's in the Auto Tiles. Error(14566): The Fitter cannot place 1 periphery component(s) due to conflicts with existing...
- 2 years ago
So turns out if I use an external clock for my IOPLL the problem is resolved.
Dotted line is the configuration in the project above resulting in the error, solid line for userclk (reference to IOPLL) from another FPGA pin works fine:
Harshx
2 years agoHi,
Thanks for contacting Intel. I'm assigned to support request.
I'll investigate on this case and get back to you soon once I have any finding. Meanwhile can you please share the following info for my better understanding.
- What's the version of Quartus you are using?
- Can you share the related files so that I can compile and check for the same error?
Thanks for your patience.
Harsh M
- mschiller-nrao2 years ago
This is in Quartus Prime Version 23.4.0 Build 79 dated 11/22/2023 SC pro Edition
(no patches installed)
The QAR file is attached
