sittinhawk's avatar
sittinhawk
1 month ago
AGI027 Dev Kit example build takes a long time
I have a DK-DEV-AGI027-RA dev kit and am trying to build the pcie_ep example project in Quartus 25.3.1. I have had the spinning progress bar stuck at 0% for over 12 hours.
It seems like it's stuck on the "IP Generation" step. Not sure if this is normal or something is wrong with my Quartus install or setup.
Any help?
  • sittinhawk's avatar
    sittinhawk
    It would be nice if it could indicate that there is a problem instead of appearing to churn.
  • sstrell's avatar
    sstrell
    IP generation should definitely not take that long.  I'd try re-downloading the example design into a new directory and recompiling.  If it happens again (I wouldn't wait 12 hours though), I'd look at the Quartus installation and maybe reinstall.  Which exact example design are you using (link?) and does it say in the Design Store that it is specifically for version 25.3.1?  I've seen version mismatches with example designs have issues.
