13 years ago
Address decoding logic for read and write in custom ip
Hello everybody,
i want the logic for custom pheripheral which has two slave ports.
first port has these signals
avs_s0_address : in std_logic_vector(1 downto 0);
avs_s0_chipselect : in std_logic;
avs_s0_write : in std_logic;
avs_s0_writedata: in std_logic_vector(7 downto 0);
avs_s0_byteenable : in std_logic :='1';
i want the address decoding logic for WRITE opetation.
similarly for other port
avs_s1_address :in std_logic_vector(1 downto 0);
avs_s1_read : in std_logic;
avs_s1_readdata :out std_logic_vector(31 downto 0);
avs_s1_byteenable: in std_logic_vector(3 downto 0) :="0100");
how to make it readdata to READ by avalon interconnect.
kindly give me the solution.
    --- Quote Start ---
    --- Quote End ---
    Here is one solution:
    avs_s1_readdata <= your_addr_00_reg when (avs_s1_address = "00") else
    your_addr_01_reg when (avs_s1_address = "00") else
    your_addr_10_reg when (avs_s1_address = "00") else
    your_addr_11_reg;
    Where addr_XX_reg is your internal registers that holds whatever the collection of readable registers are for your component.
    Note that readdata does not need to depend on read at all, it is simply a function of the address input.
    Kevin Jennigns
    Dear K_J,
    signal reg_read_data : std_logic_vector(31 downto 0);
    signal rd_en : std_logic;
    rd_en<= '1' when avs_s1_read='1' and avs_s1_address="00" else
            '1' when avs_s1_read='1' and avs_s1_address="01" else
            '1' when avs_s1_read='1' and avs_s1_address="10" else
            '1' when avs_s1_read='1' and avs_s1_address="11";
    process (clk,reset)
    begin
    if reset='1' then
    reg_read_data<=(others=>'0');
    elsif(clk'event and clk='1') then
    if rd_en='1' then
    avs_s1_readdata<=reg_read_data;
    end if;
    end if;
    Is this correct solution for READ operation.
