13 years ago
Addition of a vector with a integer in vhdl code
There is a vector A(7 down to 0).Now we have to add this vector with an integer(let it be 5).B(7 down to 0) is output.Then how to write the vhdl code.
    it depends what type A and B are. If A is a std_logic_vector you need to first convert it to an unsigned then add the integer. make sure you also include the numeric_std package (and do not add the std_logic_arith package).
    if A and B are already unsigned, you can just write:
    B <= A + 5;
    But we need to see the declaration of A and B to see what code you really need.
    I have written the code as below:
    Library IEEE;
    use IEEE.std_logic_1164.all;
    use IEEE.numeric_std.all;
    use IEEE.STD_LOGIC_UNSIGNED.ALL;
    use IEEE.STD_LOGIC_ARITH.ALL;
    entity improc is
    port (clk : in std_logic;
    ipixel : in std_logic_vector(23 downto 0);
    opixel : out std_logic_vector(23 downto 0)
    end entity improc;
    architecture rtl of improc is
    begin
    process (clk) begin
    if rising_edge (clk) then
    opixel(23 downto 16) <= std_logic_vector(unsigned( ipixel(23 downto 16)))+ conv_std_logic_vector(unsigned(9,8)));
    opixel(15 downto 8) <= std_logic_vector(unsigned( ipixel(15 downto 8)))+ conv_std_logic_vector(unsigned((9,8)));
    opixel(7 downto 0) <= std_logic_vector(unsigned( ipixel(7 downto 0)))+ conv_std_logic_vector(unsigned((9,8)));
    end if;
    end process;
    end architecture rtl;
    But it gives error.
    The main problem is that you have included std_logic_arith AND numeric_std. They conflict with each other, so you need to remove std_logic_arith (its not standard VHDL. Neither is std_logic_unsigned, but Ill let you keep that)
    the answer would then be:
    opixel(23 downto 16) <= std_logic_vector( unsigned( ipixel(23 downto 16) ) + 9 );
    Is it necessaryto convert 9 into vector form using conv_std_logic_vector.Beacuse ipixel is 8 bit and 9 is constant.Plearse help...
    No. Like I showed you, you can add an integer to an unsigned number. There is no need to use conv_std_logic_vector because you're adding an integer to an unsigned. (conv_std_logic_vector is NOT standard VHDL).
    Then what is the actual meaning of these "std_logic_vector(unsigned( ipixel(23 downto 16)))".Little bit confused...............
    ipixel is a std_logic_vector
    unsigned( ipixel(23 downto 16)) converts the top 8 bits to an unsigned type.
    std_logic_vector( unsigned( ipixel(23 downto 16)) ) converts the unsigned back to a std_logic_vector.
    A std_logic_vector is not a number, it is just a collection of bits. An unsigned type is a similar array that can be treated as an unsigned number, hence the ability to do arithmatic with it.
    So the answer I proposed:
    converts the input to an unsigned, adds 9 to it, then converts the result back to a std_logic_Vector.
