James44
2 years agoADC Toolkit - no associated hardware
Hi @ShengN_Intel So I turned off the debug option when building a .bcf file to use less logic elements because I'm using the 10M04SAE144 chip. Does this mean I won't be able to run the ADC Toolkit ...
- 2 years ago
Hi James,
Is there any more support needed after the clarification by @ShengN_Intel?
ShengN_altera
2 years agoHi,
Yes, disable Debug Path then not able to run the ADC Toolkit. Debug Path will implement high number of LEs. If wants to use that may be can use a larger board like 10M08 mentioned in video.
Sheng
