12 years ago
a pipelining module
I am designing a pipelining module which takes the outputs (I, Q) from the previous IC (block) as it inputs. After 8 posedge of clock, it will output its result (yI, yQ). At each posedge of clk, yI<=yI+yQ; YQ<=YI-YQ; (iteratively) Therefore, somehow, I need to initialize (yI, YQ) = (I, Q) in the very beginning before the iteration. I use a initial block for this initialization. However, I keep getting warning: initial value for variables (yI, yQ) should not be constant. Any ideas on this problem? What should be the correct way to handle the situation? Simplified module as follows:module test(I, Q, clk yI, yQ);
input signed [17:0] I, Q;
output signed [17:0] yI, yQ;
integer L;
initial begin
yI = I;
yQ=Q; L=0;
end
always @(posedge clk) begin
yI <= yI + yQ;
yQ <= yI - yQ;
L <= L + 1;
end
endmodule
1 Reply
    Initial block is normally used to initialize the register.
    You are trying to initialize output port in the initial blobk, thix does not make sense.
    U can change the output port name and use assignment to assign yL and yQ to these output port. Anyway, initial block is only for simulation purpose only. I think u should have a reset, to initialize during reset.
