13 years ago
A little problem how "open and close and locked door"
library ieee;
use ieee.std_logic_1164.all;
entity uppgift4a_more_2 is
port (
-- Insignaler
CLOCK, reset_n : IN std_logic;
KEY_0, KEY_1 : IN std_logic;
-- Utsignaler
LEDG_0, LEDG_1,LEDR_0,LEDR_1, led : OUT std_logic);
end entity;
architecture rtl of uppgift4a_more_2 is
-- Build an enumerated type for the state machine
type state_type is (opening_1,closing_2, open, close);
-- Register to hold the current state
signal state : state_type;
begin
process (reset_n, CLOCK)
begin
if reset_n = '0' then
state <= opening_1;
elsif (rising_edge(CLOCK)) then
case state is
when closing_2=>
if KEY_0 = '1' then
state <= close;
else
state <= closing_2;
end if;
when close =>
state <= closing_2;
when open =>
state <= opening_1;
when opening_1 =>
if KEY_1 = '1' then
state <= open;
else
state <= opening_1;
end if;
when others =>
state <= opening_1;
end case;
end if;
end process;
process (state)
begin
case state is
when closing_2=>
led <= '1';LEDG_0 <= '0'; LEDG_1 <= '0';
when open =>
LEDG_0 <= '1'; LEDG_1 <= '0'; led <= '1';
when close =>
LEDG_1 <= '1'; LEDG_0 <= '0'; led <= '0';
when opening_1 =>
led <= '0'; LEDG_0 <= '0'; LEDG_1 <= '0';
when others =>
LED_1 <= '0';LEDR_0 <= '0'; led <= '0';
when opening_1 =>
led <= '0'; LEDR_0 <= '0'; LEDR_1 <= '0';
when others =>
LEDG_1 <= '0';LEDR_0 <= '0'; led <= '0';
end case;
end case;
end process; i vonder what is wrong with this code :unsure:
end;
    What kind of error do you have? I only see a double "end case" at the end of the code.
    Error (10500): VHDL syntax error at uppgift4a_Moore_2.vhd(21) near text "open"; expecting an identifier ("open" is a reserved keyword), or a character
    Error (10500): VHDL syntax error at uppgift4a_Moore_2.vhd(42) near text "open"; expecting "(", or an identifier ("open" is a reserved keyword), or unary operator
    Error (10500): VHDL syntax error at uppgift4a_Moore_2.vhd(47) near text "open"; expecting "(", or an identifier ("open" is a reserved keyword), or unary operator
    Error (10500): VHDL syntax error at uppgift4a_Moore_2.vhd(62) near text "open"; expecting "(", or an identifier ("open" is a reserved keyword), or unary operator
    Error (10500): VHDL syntax error at uppgift4a_Moore_2.vhd(81) near text "case"; expecting "process"
    "open" is a reserved key word in VHDL syntax. You should use a different name for that state .
    what name i dont understand i thought (open) was the right so show me ...? :confused:
    As suggested by the Error information given by your compiler:
    --- Quote Start ---
    --- Quote End ---
    "open" is a reserved word in VHDL syntax.
    For example, you can change your state_type definition to:
    type state_type is (opening_1,closing_2, opened, close)
    You can use any name for this state except "open".
    Any tutorial on VHDL will give a list of reserved words in VHDL syntax.
    When writing code, you should avoid using any of these reserved words as a name of user-defined object, such as signal, variable, entity, architecture, enumerated data types, etc.
    I have done that,now i have a error Error (10500): VHDL syntax error at uppgift4a_Moore_2.vhd(13) near text ":"; expecting an identifier
    this is the text>LEDG_0, LEDG_1,LEDR_0,LEDR_1,: OUT std_logic);
    now you have an extra comma before ": OUT". Type:
    LEDG_0, LEDG_1,LEDR_0,LEDR_1 : OUT std_logic);
    But in the original code you have:
    LEDG_0, LEDG_1,LEDR_0,LEDR_1,led : OUT std_logic);
    ¿Do you delete "led"?
    This is the new one i vonder if its right or wrong and someone can help me do it right "tanks:rolleyes:"
    library ieee;
    port (
    -- Insignaler
    KEY_0, KEY_1,KEY_2,KEY_3: IN std_logic;
    -- Utsignaler
    end entity;
    type state_type is (opening_1,closing_2, opened, close,locked,locking_2,unlocked,unlocking_3);
    begin
    begin
    state <= opening_1;
    case state is
    when closing_2=>
    if KEY_0 = '1' then
    state <= close;
    else
    state <= closing_2;
    end if;
    when close =>
    state <= closing_2;
    when locking_2=>
    if KEY_2 = '1' then
    state <= locked;
    else
    state<= locking_2
    when unlocking_3=>
    if KEY_3 ='0'
    then
    state <=unlocked
    else
    state<=unlocking_3
    when opening_1 =>
    if KEY_1 = '1' then
    state <= opened;
    else
    state <= opening_1;
    end if;
    when others =>
    state <= opening_1;
    end case;
    end if;
    end process;
    process (state)
    begin
    case state is
    when closing_2=>
    when opened =>
    when close =>
    when opening_1 =>
    when others =>
    when opening_1 =>
    when others =>
    end case;
    end process;
    end;
    Syntax errors are something you should really be fixing yourself. Also, testing it is also something you should be doing yourself, not asking others to do it for you.
