13 years agoThis is the new one i vonder if its right or wrong and someone can help me do it right "tanks:rolleyes:"
library ieee; use ieee.std_logic_1164.all; entity uppgift4a_more_2 is port ( -- Insignaler CLOCK, reset_n : IN std_logic; KEY_0, KEY_1,KEY_2,KEY_3: IN std_logic; -- Utsignaler LEDG_0, LEDG_1,LEDR_0,LEDR_1,led : OUT std_logic); end entity; architecture rtl of uppgift4a_more_2 is -- Build an enumerated type for the state machine type state_type is (opening_1,closing_2, opened, close,locked,locking_2,unlocked,unlocking_3); -- Register to hold the current state signal state : state_type; begin process (reset_n, CLOCK) begin if reset_n = '0' then state <= opening_1; elsif (rising_edge(CLOCK)) then case state is when closing_2=> if KEY_0 = '1' then state <= close; else state <= closing_2; end if; when close => state <= closing_2; when locking_2=> if KEY_2 = '1' then state <= locked; else state<= locking_2 when unlocking_3=> if KEY_3 ='0' then state <=unlocked else state<=unlocking_3 when opening_1 => if KEY_1 = '1' then state <= opened; else state <= opening_1; end if; when others => state <= opening_1; end case; end if; end process; process (state) begin case state is when closing_2=> led <= '1';LEDG_0 <= '0'; LEDG_1 <= '0'; when opened => LEDG_0 <= '1'; LEDG_1 <= '0'; led <= '1'; when close => LEDG_1 <= '1'; LEDG_0 <= '0'; led <= '0'; when opening_1 => led <= '0'; LEDG_0 <= '0'; LEDG_1 <= '0'; when others => LED_1 <= '0';LEDR_0 <= '0'; led <= '0'; when opening_1 => led <= '0'; LEDR_0 <= '0'; LEDR_1 <= '0'; LEDG_1 <= '0';LEDR_0 <= '0'; led <= '0'; when others => end case; end process; end;
