10 years ago
1:8 demultiplexer using two styles behavioral and structural modeling
I need vhdl codes for 1:8 demultiplexer using two styles behavioral and structural modeling
anyone can help on that please ?!!!
check the link for the pins detail foe 74ls138 1:8 demultiplexer
http://www.uni-kl.de/elektronik-lager/417703
    Did you even try doing this assignment yourself? Asking for the solution is unlikely to get a response.
    --- Quote Start ---
    --- Quote End ---
    Yes I did but am really stuck that's why I need help if you or anyone could help on that please
    --- Quote Start ---
    Post the problems - then maybe we can help...
    --- Quote End ---
    I need the codes for 1:8 demltiplexer by two styles
    Behavioral and Structural modeling
    The details of the 1:8 demltiplexer in this link
    I appreciate your efforts for helping me dear
    1:8 demltiplexer in two styles behavioral and structural
    In need the codes for that
    This is the type of demltiplexer am working on SN54 / 74LS138
    Asking for code will not get a response. Have a go yourself and come back with problems.
    here is the work i done
    this is the structural modeling -
    but there is some errors am expecting one of them in the nand statement
    can you check out please
    library ieee;
    use ieee.std_logic_1164.all;
    entity demux1 is
    port(a0,a1,a2,e1bar,e2bar,e3:in std_logic; y0,y1,y2,y3,y4,y5,y6,y7:out std_logic);
    end demux1;
    architecture beh of demux1 is
    component inv_6
    port(a:in std_logic; b:out std_logic);
    end component;
    component nand_8
    port(k1,k2,k3:in std_logic; z:out std_logic);
    end component;
    component and_1
    port(c1bar,c2bar,c3:in std_logic; h:out std_logic);
    end component;
    signal i1,i2bar,i3bar,i4bar,i5bar,i6bar,i7bar: std_logic;
    begin
    u1:and_1 port map(e1bar,e2bar,e3,i1);
    u2:inv_6 port map(a0,i2bar);
    u3:inv_6 port map(a1,i3bar);
    u4:inv_6 port map(a2,i4bar);
    u5:inv_6 port map(i2bar,i5bar);
    u6:inv_6 port map(i3bar,i6bar);
    u7:inv_6 port map(i4bar,i7bar);
    u8:nand_8 port map(i2bar,i3bar,i4bar,i1,y0bar);
    u9:nand_8 port map(i5bar,i3bar,i4bar,i1,y1bar);
    u10:nand_8 port map(i2bar,i6bar,i4bar,i1,y2bar);
    u11:nand_8 port map(i5bar,i6bar,i4bar,i1,y3bar);
    u12:nand_8 port map(i2bar,i3bar,i7bar,i1,y4bar);
    u13:nand_8 port map(i3bar,i7bar,i5bar,i1,y5bar);
    u14:nand_8 port map(i2bar,i7bar,i6bar,i1,y6bar);
    u15:nand_8 port map(i1,i6bar,i5bar,i7bar,y7bar);
    end beh;
    library ieee;
    entity inv_6 is
    end entity;
    architecture beh1 of inv_6 is
    begin
    b<= not a;
    end beh1;
    library ieee;
    entity nand_8 is
    end entity;
    architecture beh2 of nand_8 is
    begin
    z<= ((k1) nand (k2) nand (k3));
    end beh2;
    library ieee;
    entity and_1 is
    end entity;
    architecture beh3 of and_1 is
    begin
    h<= c1bar and c2bar and c3;
    end beh3;
