10 years ago1:8 demultiplexer using two styles behavioral and structural modeling
I need vhdl codes for 1:8 demultiplexer using two styles behavioral and structural modeling anyone can help on that please ?!!! check the link for the pins detail foe 74ls138 1:8 demultiplexer ...
10 years agolibrary ieee;
use ieee.std_logic_1164.all; entity demux1 is port(a0,a1,a2,e1bar,e2bar,e3:in std_logic; y0,y1,y2,y3,y4,y5,y6,y7:out std_logic); end demux1; architecture beh of demux1 is component inv_6 port(a:in std_logic; b:out std_logic); end component; component nand_8 port(k1,k2,k3:in std_logic; z:out std_logic); end component; component and_1 port(c1bar,c2bar,c3:in std_logic; h:out std_logic); end component; signal i1,i2bar,i3bar,i4bar,i5bar,i6bar,i7bar: std_logic; begin u1:and_1 port map(e1bar,e2bar,e3,i1); u2:inv_6 port map(a0,i2bar); u3:inv_6 port map(a1,i3bar); u4:inv_6 port map(a2,i4bar); u5:inv_6 port map(i2bar,i5bar); u6:inv_6 port map(i3bar,i6bar); u7:inv_6 port map(i4bar,i7bar); u8:nand_8 port map(i2bar,i3bar,i4bar,i1,y0bar); u9:nand_8 port map(i5bar,i3bar,i4bar,i1,y1bar); u10:nand_8 port map(i2bar,i6bar,i4bar,i1,y2bar); u11:nand_8 port map(i5bar,i6bar,i4bar,i1,y3bar); u12:nand_8 port map(i2bar,i3bar,i7bar,i1,y4bar); u13:nand_8 port map(i3bar,i7bar,i5bar,i1,y5bar); u14:nand_8 port map(i2bar,i7bar,i6bar,i1,y6bar); u15:nand_8 port map(i1,i6bar,i5bar,i7bar,y7bar); end beh;
