Tim10
7 years ago10996 Verilog HDL error at <location>: parameter "<name>" has no initial or actual value
Hi, I'm trying to pass a parameter down a chain of modules, but I get an error in top.v about the parameter having no initial nor actual value. Any ideas? Simple typo? Thanks, Tim. testbench.v ...
Abe
7 years agoYes, @ak6dn is right. All parameters used within a module should be initialized with a default value. Then you can override them when creating instances.
module top
parameter WIDTH = 1
input wire clock,
input wire [WIDTH-1:0 ] in,
output reg [WIDTH-1:0] out
bottom
.WIDTH(WIDTH)
bottom_instantiation
.clock(clock),
.in(in),
.out(out)
endmodulemodule bottom
parameter WIDTH = 1
input wire clock,
input wire [WIDTH-1:0] in,
output reg [WIDTH-1:0] out // reg is a keyword in Verilog, Do not use it as a signal/variable name.
endmodule
