12 years ago*** Routing fails ***, Router estimated peak interconnect usage exceeding 100%
I have a big design trying to fit in stratix4 530 device using Quartus II 64 bit. **** Routing estimated average interconnect usage in 24% of the available device resource *** All this means that routing should be OK for my design but thee estimated peak interconnect usage is 110% and ROUTING FAILS. This seems to mean that some part of the design is very much concentrated. In chip planner I see around the design are all empty. Is there any setting in Quartus or any way to spread the design so the routing is not so much codensed? More info: Combinational ALUTs is 24%, Dedicated logic registers is 75%, DSP block 18-bit elements is 3% and memory ALUTs is 0% Thanks a lot Alex
