15 years agoWrong information on Nios Wiki
I downloaded nios2-linux-20090929.tar as indicated in the Nios Wiki's "Install Nios II Linux". When I try to : make vendor_hwselect SYSPTF=.... It doesn't know what to do. I can not use the PTF file. Is there disconnect with the instructions????? Thanks:(6 Replies
I just did it in this morning.
and I could do that. I don't know how far you have done. have you specified ptf file by full path? - Altera_Forum
Have you tried insert ../ before the path of ptf?
if your .ptf is in the same path of uclinux-dist --- Quote Start --- make vendor_hwselect SYSPTF=../my_soc.ptf --- Quote End --- Regards, Caio Pereira - Altera_Forum
I spelled out the complete path to the ptf file. It failed everytime.
I installed the previous release, and it works just fine: nios2-linux-20090730.tar - Altera_Forum
You have to do a "make menuconfig" then select nothing before doing a make vendor for the first time.
Good luck - Altera_Forum
Also realize that the wiki contradicts itself in at least one place.
http://www.alterawiki.com/wiki/installnios2linux (http://www.alterawiki.com/wiki/installnios2linux) refers to both 20090929 and 20090730. I had luck with 20090730. For your first boot, once you have the toolchain (I used the prebuilt toolchain), then follow the instructions at http://www.alterawiki.com/wiki/uclinuxdist (http://www.alterawiki.com/wiki/uclinuxdist). for me it was: untar cd nios2-linux ./checkout cd uClinux-dist make menuconfig select only the "default all options (lose changes) make vendor_hwselect SYSPTF=/absolute/path/to/.ptf make David - Altera_Forum
--- Quote Start --- Hello, ... It doesn't know what to do. I can not use the PTF file. Is there disconnect with the instructions????? Thanks:( --- Quote End --- This looks to me that you are not in the right folder. You have to be in the uClinux-dist folder, else this command will be unknown.
