15 years agoWrong information on Nios Wiki
Hello, I downloaded nios2-linux-20090929.tar as indicated in the Nios Wiki's "Install Nios II Linux". When I try to : make vendor_hwselect SYSPTF=.... It doesn't know what to do. I ...
15 years ago --- Quote Start --- Hello, ... It doesn't know what to do. I can not use the PTF file. Is there disconnect with the instructions????? Thanks:( --- Quote End --- This looks to me that you are not in the right folder. You have to be in the uClinux-dist folder, else this command will be unknown.
