15 years agoWrong information on Nios Wiki
Hello, I downloaded nios2-linux-20090929.tar as indicated in the Nios Wiki's "Install Nios II Linux". When I try to : make vendor_hwselect SYSPTF=.... It doesn't know what to do. I ...
15 years agoAlso realize that the wiki contradicts itself in at least one place.
http://www.alterawiki.com/wiki/installnios2linux (http://www.alterawiki.com/wiki/installnios2linux) refers to both 20090929 and 20090730. I had luck with 20090730. For your first boot, once you have the toolchain (I used the prebuilt toolchain), then follow the instructions at http://www.alterawiki.com/wiki/uclinuxdist (http://www.alterawiki.com/wiki/uclinuxdist). for me it was: untar cd nios2-linux ./checkout cd uClinux-dist make menuconfig select only the "default all options (lose changes) make vendor_hwselect SYSPTF=/absolute/path/to/.ptf make David
