20 years agowrite & read SDRAM chip
hi all
I try to read and write the external 8M SDRAM chip. At the Nios II IDE, my system library and "Linker Script" with program memory(.text), Read-only data memory(.rodata), Read/Write data memory (.rwdata), Heap memory, Stack memory all setting another RAM chip "sram_0". My program is below: # include <stdio.h># include <alt_types.h># include <io.h># include <system.h># include <string.h># include "system.h" int main(void) { unsigned int value = 0; unsigned int pattern = 0x10; unsigned int i, memory_size; memory_size = 0x800; //SDRAM actual size is 0x7FFFFF for(i = 0; i< memory_size; i=i+0x10) { IOWR_16DIRECT((SDRAM_0_BASE), i, pattern); value = IORD_16DIRECT((SDRAM_0_BASE), i); printf("%d,%d\n", i,value); } return 0; } but in the Console with result is only display 6 data: 0,16 16,16 32,16 48,16 64,16 80,16 Could anyone tell me where it is fault ? At the SOPC Builder->More Settings->Exception Address & Memodule my setting is sdram_0. is this need change to sram_0 or not ? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif3 Replies
You've answered it, yourself. You're writing over the code at your Exception Address (starting at offset 0x20) in your SDRAM.
Cheers, - slacker - Altera_Forum
--- Quote Start --- originally posted by slacker@Jun 2 2006, 12:02 AM you've answered it, yourself. you're writing over the code at your exception address (starting at offset 0x20) in your sdram.cheers,
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15784)
--- quote end ---
--- Quote End --- hi slacker The problem has already been solved thanks for your reply
--- Quote Start --- originally posted by suway1219+jun 2 2006, 02:00 am--><div class='quotetop'>quote (suway1219 @ jun 2 2006, 02:00 am)</div>--- quote start ---
<!--quotebegin-slacker@Jun 2 2006, 12:02 AM you've answered it, yourself. you're writing over the code at your exception address (starting at offset 0x20) in your sdram.
cheers,
- slacker
--- quote end ---
--- Quote End --- hi slacker The problem has already been solved thanks for your reply <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15785)</div> [/b] --- Quote End --- Hi,suway1219 I will write and read data from SDRAM. so, can you give a complete example? thx again. Regards Faye
