20 years agowrite & read SDRAM chip
hi all I try to read and write the external 8M SDRAM chip. At the Nios II IDE, my system library and "Linker Script" with program memory(.text), Read-only data memory(.rodata), Read/Write data m...
20 years ago --- Quote Start --- originally posted by slacker@Jun 2 2006, 12:02 AM you've answered it, yourself. you're writing over the code at your exception address (starting at offset 0x20) in your sdram.
cheers,
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15784)
--- quote end ---
--- Quote End --- hi slacker The problem has already been solved thanks for your reply
