20 years agowrite & read SDRAM chip
hi all I try to read and write the external 8M SDRAM chip. At the Nios II IDE, my system library and "Linker Script" with program memory(.text), Read-only data memory(.rodata), Read/Write data m...
19 years ago --- Quote Start --- originally posted by suway1219+jun 2 2006, 02:00 am--><div class='quotetop'>quote (suway1219 @ jun 2 2006, 02:00 am)</div>
--- quote start ---
<!--quotebegin-slacker@Jun 2 2006, 12:02 AM you've answered it, yourself. you're writing over the code at your exception address (starting at offset 0x20) in your sdram.
cheers,
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15784)
--- quote end ---
--- Quote End --- hi slacker The problem has already been solved thanks for your reply <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15785)</div> [/b] --- Quote End --- Hi,suway1219 I will write and read data from SDRAM. so, can you give a complete example? thx again. Regards Faye
