21 years agoWhy my NFS not work
I creat a Nios II Linux application project and want to run it in cyclone1c20 borad through NFS.
I use command mount -t nfs 192.168.0.7:/mnt/nfs /mnt/nfs -n 192.168.0.7 is my Linux host IP .But my NFS not work rightly . The information tell me time out ,why?9 Replies
You have to make sure you have allowed access to your nfs directory on the host machine by specifying it in /etc/exports.
Normally you export a different directory other than /mnt/nfs. If you want to export /home/user from your host machine and your nios2 IP address is "w.x.y.z", then try the following in etc exports. /home/user w.x.y.z(rw,no_root_squash) You then might have to restart the nfs server on your host machine. On the nios2, try using the following line in your /etc/rc script, or manually type it in after logging in. /bin/mount -t nfs 192.168.0.7:/home/user /mnt/nfs -n -o nolock & Hopefully this helps. - Altera_Forum
I do it as you tell me ,but my NFS still not work ,why?
The Nios information as follows:# nfs warning :mount version older than Kernel# NFS: NFSv3 not supported# mount:PRC:Time out - Altera_Forum
Hi su-30mk,
> The Nios information as follows: ># nfs warning :mount version older than Kernel ># NFS: NFSv3 not supported ># mount:PRC:Time out This looks like portmap is not running. Make sure you have RPC and the portmapper started prior to running the mount. Regards, --Scott BTW: if you need to do simple NFS testing (file download), you can use the u-boot boot monitor. - Altera_Forum
You said portmap is not running.What can i do?Can you give me some example and tell me how let portmap runing,thank you very much.
also make sure NFS is enabled in your kernel configuration.
Hi su-30mk,
> an you give me some example and tell me how let portmap runing You can simply enter the command: $ portmap I haven't used NFS with the Nios-II uClinux yet. I'm assuming that it is indeed available with the other network apps (it should be if the nfs server is available). Regards, --Scott - Altera_Forum
Yes i do it ,but system not support portmap
You can try building portmap using the sources from uClinux.org. Regards, --Scott - Altera_Forum
I have a related problem. I have a uKit board with a Cyclone running uClinux.
I am using the configuration stated in the first reply: <div class='quotetop'>QUOTE </div> --- Quote Start --- /bin/mount -t nfs 192.168.0.7:/home/user /mnt/nfs -n -o nolock &[/b] --- Quote End --- When I run this, I get the warning: <div class='quotetop'>QUOTE </div> --- Quote Start --- # nfs warning :mount version older than Kernel[/b] --- Quote End --- I am able to browse through the mounted directory to a point, but if I try to copy "cp" anything from the /mnt/nfs over to my ramdisk at /tmp, then it hangs with no error messages. This also occurs if I try to run something directly from the nfs mounted directory. My kernel that is on my host machine is older, it is a 2.4.20 kernel. I'm guessing that is why I get the warning. However, should this really be a problem? I am hoping that I can use nfs to speed up my development cycle, but so far it hasn't worked out for me. Does anyone have any ideas on why it would be unstable?
