21 years agoWhy my NFS not work
I creat a Nios II Linux application project and want to run it in cyclone1c20 borad through NFS. I use command mount -t nfs 192.168.0.7:/mnt/nfs /mnt/nfs -n 192.168.0.7 is my Linux host IP .But ...
21 years agoHi su-30mk,
> an you give me some example and tell me how let portmap runing You can simply enter the command: $ portmap I haven't used NFS with the Nios-II uClinux yet. I'm assuming that it is indeed available with the other network apps (it should be if the nfs server is available). Regards, --Scott
