21 years agoWhy my NFS not work
I creat a Nios II Linux application project and want to run it in cyclone1c20 borad through NFS. I use command mount -t nfs 192.168.0.7:/mnt/nfs /mnt/nfs -n 192.168.0.7 is my Linux host IP .But ...
21 years agoYou have to make sure you have allowed access to your nfs directory on the host machine by specifying it in /etc/exports.
Normally you export a different directory other than /mnt/nfs. If you want to export /home/user from your host machine and your nios2 IP address is "w.x.y.z", then try the following in etc exports. /home/user w.x.y.z(rw,no_root_squash) You then might have to restart the nfs server on your host machine. On the nios2, try using the following line in your /etc/rc script, or manually type it in after logging in. /bin/mount -t nfs 192.168.0.7:/home/user /mnt/nfs -n -o nolock & Hopefully this helps.
