20 years ago
Why cross compile fails ?
hello All once again.. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
as i said before, i am making an MPEG-2 decoder on uClinux .. i almost
finished the VGA controller using some external circuits.
the S/w part, i use the code provided from mpeg.org .. it is tracking the standard
step by step with almost no optimization.
i found a much better code here: libmpeg2
http://libmpeg2.sourceforge.net/files/mpeg2dec-0.4.0.tar.gz (http://libmpeg2.sourceforge.net/files/mpeg2dec-0.4.0.tar.gz)
this library come with 6 sample programs (in doc folder)
i want to compile the library and use sample6
it worked on my PC giving super results..
but for many days, i cant compile it for nios using your prebuilt binary cross compiler <http://nioswiki.jot.com/WikiHome/OperatingSystems/BinaryToolchain>
it gives weird errors even when i disable cpu accelerate options when doing " ./config "
Please guys , i know i ask a lot .. but beleive me , i tried so hard,,
I ask you to try to compile the code .. if you succeed, pls mail me the executable sample6
or simply tell me what was your trick ,,
Sorry for interrupting you ,, but i really need you !
Thanks for everything.
Yours,
Tarek
[email protected]
