20 years agoWhy cross compile fails ?
hello All once again.. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif as i said before, i am making an MPEG-2 decoder on uClinux .. i almost finished the VGA c...
20 years ago --- Quote Start --- originally posted by hippo@Jul 12 2006, 04:10 PM the wiki is udpated to ver 3, as your wish.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16835)
--- quote end ---
--- Quote End --- thanks .. i tested the decoded frames .. they had some error blocks .. both the rgb (ppm-format) and the yuv fraes had these errors... the same code was tested on PC ..was working perfectly.. the code uses <inttypes.h> <stdlib.h><stdio.h> .. are they correctly used by the compiler.. ? i think .. maybe .. the datatypes differ from PC to uClinux .. this can make some data cropping producing the error blocks in the frames .. i dont know .. what do u say ? thanks for all http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
