20 years agoWhy cross compile fails ?
hello All once again.. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif as i said before, i am making an MPEG-2 decoder on uClinux .. i almost finished the VGA c...
20 years agoi tried to insert the " -02" flag .. same results..
did you try to run the mpeg2dec on your board ? the frames still contain errors. can you tell me the size of the " uint8_t " for example (under uClinux )?? is it equivalent to that on linux ? i checked (more than once) the codes output on the PC ... the frames are decoded correctly.. Also i noticed that the error frames have weird black and green blocks.. due to error from the IDCT process.. also there is an error in the motion compensation. what i am trying to say .. the software code is good .. but something else is wrong http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
