mametarou963's avatar
mametarou963
3 years ago
When compiling with Nios II SBT, the optimize option (-O2) causes it to stop working.
Hi.
I am currently developing on Nios II Cyclone 10,
but when I add the optimization option, it stops working.
Is there any possible cause for this?
Development environment is as follows:
* FPGA:Cyclone10 10CL016YE144C8G
* ROM:EPCQ16ASI8N
* Quartus Prime:Ver18.0
Details are as follows Sorry this is so long.
-----detail-----
This is the source code around the area where the problem seems to be occurring.
```C
#define GG_MMIO_OUTPUT_STS_ROW_MAX 3
#define GG_REG_IOWR_ADDRESS_DECODER(base, offset, data) IOWR_16DIRECT(base, offset * 4, data)
#define EXT_BUFFERS_BASE 0x3400000
#define GG_REG_ADDRESS_DECODER_BASE EXT_BUFFERS_BASE
unsigned char ggMmioInitialize(void)
unsigned char result = GG_MMIO_RET_OK;
GG_TIM_ATTRIBUTE_ST timParamSt;
unsigned char idx;
for( idx=0; idx<GG_MMIO_OUTPUT_STS_ROW_MAX; idx++ )
GG_REG_IOWR_ADDRESS_DECODER( GG_REG_ADDRESS_DECODER_BASE, idx, 0x00 ); // stops here.
memset( ggMmioInputSettingsTable, GG_SYS_DEFAULT_BYTE, sizeof(GG_MMIO_INPUT_PARAM_ST) * GG_MMIO_INPUT_SETTINGS_MAX );
* When the following code is compiled with optimization option level2(-O2) in Debuger and then executed, it stops at the comment line `stops here`.
* If the optimization option is set to level 0(-O0), it runs without problems.
* If you apply the optimization option level2 and add `#pragma GCC optimize ("O0")` so that only the function `ggMmioInitialize` is not optimized, it will run without problems.
I believe these are problems with the compile-time optimization of the function `ggMmioInitialize`.
To investigate the cause in detail, I compared the assembler code WITHOUT OPTIMIZATION with the assembler code WITH OPTIMIZATION.
The two codes are shown below, respectively.
* assembler code WITHOUT OPTIMIZATION
0: defff704 addi sp,sp,-36
4: dfc00815 stw ra,32(sp)
8: df000715 stw fp,28(sp)
c: df000704 addi fp,sp,28
10: e03ffb05 stb zero,-20(fp)
unsigned char idx;
14: e03ffb45 stb zero,-19(fp)
18: 00000b06 br 48 <ggMmioInitialize+0x48>
1c: e0bffb43 ldbu r2,-19(fp)
20: 1085883a add r2,r2,r2
24: 1085883a add r2,r2,r2
28: 1007883a mov r3,r2
2c: 0080d034 movhi r2,832
30: 1885883a add r2,r3,r2
34: 0007883a mov r3,zero
38: 10c0002d sthio r3,0(r2)
unsigned char idx;
3c: e0bffb43 ldbu r2,-19(fp)
40: 10800044 addi r2,r2,1
44: e0bffb45 stb r2,-19(fp)
48: e0bffb43 ldbu r2,-19(fp)
4c: 108000f0 cmpltui r2,r2,3
50: 103ff21e bne r2,zero,1c <mmioInputStatusSamplingTimerExpired+0xfffff4b8>
54: 01800504 movi r6,20
58: 01403fc4 movi r5,255
5c: 01000034 movhi r4,0
60: 21000004 addi r4,r4,0
64: 00000000 call 0 <ggMmioInitialize>
* assembler code WITH OPTIMIZATION
c: defff804 addi sp,sp,-32
10: dfc00715 stw ra,28(sp)
14: dc000615 stw r16,24(sp)
unsigned char idx;
18: 0080d034 movhi r2,832
1c: 1000002d sthio zero,0(r2)
20: 10800104 addi r2,r2,4
24: 1000002d sthio zero,0(r2)
28: 0080d034 movhi r2,832
2c: 10800204 addi r2,r2,8
30: 1000002d sthio zero,0(r2)
memset( ggMmioInputSts, GG_SYS_DEFAULT_BYTE_ZERO, sizeof(ggMmioInputSts) );
34: 00c00034 movhi r3,0
There does not appear to be anything wrong with either.
The following are among the codes that have been optimized.
sthio zero,0(r2)
Assuming we are stopping at this instruction.
To prevent the operand `zero` from being taken for the opcode `sthio`,
I modified the source as follows
```C
volatile int write_data = 0x00; // fixed
unsigned char idx;
GG_REG_IOWR_ADDRESS_DECODER( GG_REG_ADDRESS_DECODER_BASE, idx, write_data ); // fixed
The comment line `fixed` is the modified line.
The compiled assembler code sequence with optimization (-O2) looks like this
c: defff704 addi sp,sp,-36
unsigned char idx;
10: d8000615 stw zero,24(sp)
14: d8c00617 ldw r3,24(sp)
18: dfc00815 stw ra,32(sp)
1c: dc000715 stw r16,28(sp)
unsigned char idx;
20: 0080d034 movhi r2,832
24: 10c0002d sthio r3,0(r2)
28: d8c00617 ldw r3,24(sp)
2c: 10800104 addi r2,r2,4
30: 10c0002d sthio r3,0(r2)
34: d8c00617 ldw r3,24(sp)
38: 0080d034 movhi r2,832
3c: 10800204 addi r2,r2,8
40: 10c0002d sthio r3,0(r2)
The operand `r3` is changed to take the operand `r3` for the opcode `sthio`.
This change allows us to run.
At length, my questions are as follows.
* It stopped working when I put on the optimize option. Is there any possible cause for this?
* Based on my investigation, it appears that the `sthio zero ... `assembler code appears to be stuck when outputting
Does this sequence of assembler code have anything to do with the inability to execute?
Or is there another cause?
Best regards.
