mametarou963
3 years agoWhen compiling with Nios II SBT, the optimize option (-O2) causes it to stop working.
Hi.
I am currently developing on Nios II Cyclone 10, but when I add the optimization option, it stops working. Is there any possible cause for this?
Development environment is as follows: * FP...
EBERLAZARE_I_Intel
3 years agoHi,
Got it, I will need to check with our internal team on this.
Just to check, if its possible if you share the example design for this? Also which version again are you using and your machine environment that you tested this previously?
