mametarou963
3 years agoWhen compiling with Nios II SBT, the optimize option (-O2) causes it to stop working.
Hi.
I am currently developing on Nios II Cyclone 10, but when I add the optimization option, it stops working. Is there any possible cause for this?
Development environment is as follows: * FP...
mametarou963
3 years agoThere were no problems with build or compile.
However, when I run it, execution stops near the following code
sthio zero,0(r2)
If you do not take `zero` as an operand as shown above, you can execute the function without any problem.
Specifically, I tried the following two
* Using pragma for the function in question and not optimizing it so that it takes a non-zero register as its operand
* using `volatile` for a variable that is an operand, so that it takes a non-zero register as an operand
If I build and compile in these ways, it runs without any problem.
Therefore, we thought that the problem might be related to the execution of the operand `zero` for the opcode `sthio`.
