Web Server
I'm using the uCLinux ported by Microtronix. I'm trying to use the web server but I can't see the initial page. I use the open core ethernet. I built the filesystem as described in the linux quick start guide. I can use ftp and telnet but when I type the IP in the web browser, I can't see the web page. Can someone help me? Thanks a lot, Marco19 Replies
What direction were those packets in? If you could label every packet with its direction, that would be helpful.
Here is the summary of the Traffic. IP 192.168.1.233 is my PC and IP 192.168.1.239 is the uClinux board.
Frame number 1 - 9 is the small index.html -> its ok Frame number 11 - 19 is the large index.html (index_old.html) -> not ok No. Time Source Destination Protocol Info 1 0.000000 192.168.1.233 192.168.1.239 TCP 1059 > http [SYN] Seq=0 Ack=0 Win=64240 Len=0 MSS=1460 2 0.004007 192.168.1.239 192.168.1.233 TCP http > 1059 [SYN, ACK] Seq=0 Ack=1 Win=5840 Len=0 MSS=1460 3 0.004033 192.168.1.233 192.168.1.239 TCP 1059 > http [ACK] Seq=1 Ack=1 Win=64240 Len=0 4 0.004553 192.168.1.233 192.168.1.239 HTTP GET /index.html HTTP/1.1 5 0.005852 192.168.1.239 192.168.1.233 TCP http > 1059 [ACK] Seq=1 Ack=266 Win=6432 Len=0 6 0.017285 192.168.1.239 192.168.1.233 HTTP HTTP/1.0 200 OK (text/html) 7 0.153002 192.168.1.233 192.168.1.239 TCP 1059 > http [ACK] Seq=266 Ack=347 Win=63894 Len=0 8 10.017317 192.168.1.239 192.168.1.233 TCP http > 1059 [FIN, ACK] Seq=347 Ack=266 Win=6432 Len=0 9 10.017377 192.168.1.233 192.168.1.239 TCP 1059 > http [ACK] Seq=266 Ack=348 Win=63894 Len=0 10 10.027148 192.168.1.233 192.168.1.239 TCP [TCP ZeroWindow] [TCP Dup ACK 9#1] 1059 > http [RST] Seq=266 Ack=348 Win=0 Len=0 11 11.036714 192.168.1.233 192.168.1.239 TCP 1060 > http [SYN] Seq=0 Ack=0 Win=64240 Len=0 MSS=1460 12 11.037430 192.168.1.239 192.168.1.233 TCP http > 1060 [SYN, ACK] Seq=0 Ack=1 Win=5840 Len=0 MSS=1460 13 11.037454 192.168.1.233 192.168.1.239 TCP 1060 > http [ACK] Seq=1 Ack=1 Win=64240 Len=0 14 11.037967 192.168.1.233 192.168.1.239 HTTP GET /index_old.html HTTP/1.1 15 11.039311 192.168.1.239 192.168.1.233 TCP http > 1060 [ACK] Seq=1 Ack=338 Win=6432 Len=0 16 11.050942 192.168.1.239 192.168.1.233 HTTP Continuation 17 11.050983 192.168.1.233 192.168.1.239 TCP [TCP Dup ACK 13#1] 1060 > http [ACK] Seq=338 Ack=1 Win=64240 Len=0 SLE=2575009540 SRE=2575009617 18 21.045938 192.168.1.239 192.168.1.233 TCP http > 1060 [FIN, ACK] Seq=1102 Ack=338 Win=6432 Len=0 19 21.045984 192.168.1.233 192.168.1.239 TCP [TCP Dup ACK 13#2] 1060 > http [ACK] Seq=338 Ack=1 Win=64240 Len=0 SLE=2575009540 SRE=2575009618 - Altera_Forum
So what do you get in response if you do:
<div class='quotetop'>QUOTE </div> --- Quote Start --- telnet 192.168.1.239 80 GET /index_old.html HTTP/1.1 Host: 192.168.1.239[/b] --- Quote End --- (note the extra blank line at the end.) What does the server send back to you? - Altera_Forum
do you mean
telnet open 192.168.1.239 80 ? Then I have no response until the timeout is reached. - Altera_Forum
Can you use a unix box or telnet from cygwin under windows? I'm not familiar with the toy tools that come with windows, and I don't think that windows telnet is powerful enough to do this sort of debugging.
I have tested with telnet under linux. I created 2 testcases. Case 1 was a small website. In case 2, I added some characters to this website.
result case 1: Marco@linux:~> telnet 192.168.1.239 80 Trying 192.168.1.239... Connected to 192.168.1.239. Escape character is '^]'. GET / HTTP/1.1 Host: 192.168.1.239 HTTP/1.0 200 OK Date: Tue, 30 Nov 1999 00:03:35 GMT Server: Boa/0.93.15 Connection: close Content-Type: text/html Content-Length: 525 Last-Modified: Tue, 30 Nov 1999 00:52:25 GMT <html> <head><title>Microtronix uKit</title></head> <body bgcolor="white" text="black"> <td>Hello html test xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx</td> <td>Hello html test xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx</td> <td>Hello html test xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx</td> <td>Hello html test xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx</td> <td>Hello html test xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx</td> <td>Hello xxxxxxxxxxxxxx</td> </body> </html> Connection closed by foreign host. Marco@linux:~> result case 2 Marco@linux:~> telnet 192.168.1.239 80 Trying 192.168.1.239... Connected to 192.168.1.239. Escape character is '^]'. GET / HTTP/1.1 Host: 192.168.1.239 Connection closed by foreign host. Marco@linux:~> - Altera_Forum
Ok, so we can see where it's failing, at least (at Boa's end, before it tries to do anything at all).
Man it would be nice to strace boa to see what it's up to. Failing that, can you cat the file on the filesystem? I mean, just make sure that any old process can read it successfully. Also, can you try creating an html file of roughly the same size as old_index.html just to try to eliminate size as an issue? - Altera_Forum
I made some tests with filetransfer over ftp yesterday.
I can transfer files with any filesize (small and large files) to the uCLinux board. but I couldn't download these files from uClinux board to the PC. I only could download files with size smaller than approximately 520bytes. That means files fitting in one ethernet packet. I think there is a problem with tx-buffering in the ethernet kernel driver. When I compile the kernel, I receive some warnings in open_eth.c. - Altera_Forum
I solved my problem. I think the reason was the clock delay (phase) for the SDRAM. To solve the problem I changed the CPU clock in 2x Ozsillator clock (65.536MHz). The delay for the SDRAM clock is 170 degree. Now it runs on the Microtronix Cyclone 1C20 Developement board.
