21 years agoWeb Server
Hello, I'm using the uCLinux ported by Microtronix. I'm trying to use the web server but I can't see the initial page. I use the open core ethernet. I built the filesystem as des...
21 years agoOk, so we can see where it's failing, at least (at Boa's end, before it tries to do anything at all).
Man it would be nice to strace boa to see what it's up to. Failing that, can you cat the file on the filesystem? I mean, just make sure that any old process can read it successfully. Also, can you try creating an html file of roughly the same size as old_index.html just to try to eliminate size as an issue?
