21 years agoWeb Server
Hello, I'm using the uCLinux ported by Microtronix. I'm trying to use the web server but I can't see the initial page. I use the open core ethernet. I built the filesystem as des...
21 years agoHello,
I solved my problem. I think the reason was the clock delay (phase) for the SDRAM. To solve the problem I changed the CPU clock in 2x Ozsillator clock (65.536MHz). The delay for the SDRAM clock is 170 degree. Now it runs on the Microtronix Cyclone 1C20 Developement board.
