11 years ago
Variable Precision DSP in Arria V Devices
hey folks,
I am new to altera stuff. I am porting my design from xilinx devices to altera devices. In that process am facing problems with DSPs porting.
I am not finding dsp in altera similar to DSP48E1 to do functions like (axb) + c. I found one document Variable Precision DSP
in Arria V Devices, but not finding a way to use this in Arria v. I am using Quartus II 14.0 version(trial version). I didn't even find in Ip catalog.
Can some one help me on this.
Thanks in advance.
    --- Quote Start ---
    I gave you the code to infer them already.
    I suggest reading the VHDL coding guidelines for inference.
    http://www.altera.co.uk/literature/hb/qts/qts_qii51007.pdf
    --- Quote End ---
    hey,
    Thanks for info..
    I synthesized following code which I found in the above document. It's inferring dsp and 17 luts for adder, 39 registers. Actually it should infer adder also inside dsp.
    module unsig_altmult_accum (dataout, dataa, datab, clk, aclr, clken);
    input [7:0] dataa, datab;
    input clk, aclr, clken;
    output reg[16:0] dataout;
    reg [7:0] dataa_reg, datab_reg;
    reg [15:0] multa_reg;
    wire [15:0] multa;
    wire [16:0] adder_out;
    assign multa = dataa_reg * datab_reg;
    assign adder_out = multa_reg + dataout;
    always @ (posedge clk or posedge aclr)
    begin
    if (aclr)
    begin
    dataa_reg <= 8'b0;
    datab_reg <= 8'b0;
    multa_reg <= 16'b0;
    dataout <= 17'b0;
    end
    else if (clken)
    begin
    dataa_reg <= dataa;
    datab_reg <= datab;
    multa_reg <= multa;
    dataout <= adder_out;
    end
    end
    endmodule
    --- Quote Start ---
    hey,
    Thanks for info..
    --- Quote End ---
    No it wont. Like we said, the DSPs only have pre-multiplier adders. So you need to do any adition before the multiply to even hope that the adder goes in the DSP.
    Finally I found solution. If we don't register multiplier output, it infers adder also into dsp.
    with the following code.
    wire [35:0] mul_out = ((mul_a_in[17:0]) * (mul_b_in[17:0]));
    assign adder_out = $signed(add_c_in[35:0] + mul_out);
    it can do (36 bit + (18 x 18)).
    but unless you register the adder output, you're going to get poorer fmax.
