11 years agoVariable Precision DSP in Arria V Devices
hey folks, I am new to altera stuff. I am porting my design from xilinx devices to altera devices. In that process am facing problems with DSPs porting. I am not finding dsp in altera similar...
11 years ago --- Quote Start --- I gave you the code to infer them already. I suggest reading the VHDL coding guidelines for inference. http://www.altera.co.uk/literature/hb/qts/qts_qii51007.pdf --- Quote End --- hey, Thanks for info.. I synthesized following code which I found in the above document. It's inferring dsp and 17 luts for adder, 39 registers. Actually it should infer adder also inside dsp. module unsig_altmult_accum (dataout, dataa, datab, clk, aclr, clken); input [7:0] dataa, datab; input clk, aclr, clken; output reg[16:0] dataout; reg [7:0] dataa_reg, datab_reg; reg [15:0] multa_reg; wire [15:0] multa; wire [16:0] adder_out; assign multa = dataa_reg * datab_reg; assign adder_out = multa_reg + dataout; always @ (posedge clk or posedge aclr) begin if (aclr) begin dataa_reg <= 8'b0; datab_reg <= 8'b0; multa_reg <= 16'b0; dataout <= 17'b0; end else if (clken) begin dataa_reg <= dataa; datab_reg <= datab; multa_reg <= multa; dataout <= adder_out; end end endmodule
