19 years agoUsing NIOS II with DE2
Hello I am new to the DE2 and using it for my senior design project. I tried running the "hello_world" tutorial from NIOS II on the DE2 board with no success.
Is there something I did wrong or are there any .sof, .ptf and C/C++ files anyone can send me to use a starting template for the DE2? Thanks.3 Replies
Can you be more specific about what went wrong? The DE2 system cd has pretty much everything you need to get started with the board.
--- Quote Start --- originally posted by benway@Feb 14 2007, 01:04 PM can you be more specific about what went wrong? the de2 system cd has pretty much everything you need to get started with the board.<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21566)
--- quote end ---
--- Quote End --- I tried running the "hello_world" tutorial from NIOS II IDE on the DE2 board, and got the following message: "Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused "
--- Quote Start --- originally posted by kofinator+feb 14 2007, 10:24 pm--><div class='quotetop'>quote (kofinator @ feb 14 2007, 10:24 pm)</div>--- quote start ---
<!--quotebegin-benway@Feb 14 2007, 01:04 PM can you be more specific about what went wrong? the de2 system cd has pretty much everything you need to get started with the board.
--- quote end ---
--- Quote End --- I tried running the "hello_world" tutorial from NIOS II IDE on the DE2 board, and got the following message: "Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused " <div align='right'><{post_snapback}> (index.php?act=findpost&pid=21570)</div> [/b] --- Quote End --- Is your design passing the Timing Analyser ?? What is the clock speed of your nios processor ?
