19 years agoUSbHost have some problem!
Hi,everybody
I used uClinux-dist-2006-08-03 dist and DE2 board. I following "Wiki home's UsbHost" steps and enabled "fdisk" and "mount" on busybox. desplay following message: uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: PID hash table entries: 64 (order: 6, 256 bytes) Dentry cache hash table entries: 1024 (order: 0, 4096 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 5760k/8192k RAM, 0k/0k ROM (1524k kernel code, 817k data) Mount-cache hash table entries: 512 NET: Registered protocol family 16 SCSI subsystem initialized usbcore: registered new driver usbfs usbcore: registered new driver hub NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 1024 (order: 0, 4096 bytes) TCP bind hash table entries: 1024 (order: 0, 4096 bytes) TCP: Hash tables configured (established 1024 bind 1024) TCP reno registered io scheduler noop registered io scheduler deadline registered (default) Serial: JTAG UART driver $Revision: 1.1 $ ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart usbmon: debugfs is not available driver isp1362-hcd, 2005-04-04 isp1362-hcd isp1362-hcd: ISP1362 Host Controller isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1 isp1362_hc_reset: Clock not ready after 20ms isp1362-hcd isp1362-hcd: irq 4, io mem 0x80900080 isp1362_hc_start: isp1362-hcd isp1362-hcd: ISP1362 Memory usage: isp1362-hcd isp1362-hcd: ISTL: 2 * 256: 512 @ $0000:$0100 isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8): 1152 @ $0200 isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8): 2304 @ $0680 isp1362-hcd isp1362-hcd: USED/FREE: 3968 128 usb usb1: Product: ISP1362 Host Controller usb usb1: Manufacturer: uClinux 2.6.17-uc1 isp1362-hcd usb usb1: SerialNumber: isp1362-hcd usb usb1: configuration# 1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected ISP1362 Host Controller, irq 4 Initializing USB Mass Storage driver... usbcore: registered new driver usb-storage USB Mass Storage support registered. TCP bic registered NET: Registered protocol family 1 NET: Registered protocol family 17 Freeing unused kernel memory: 592k freed (0x1a8000 - 0x23b000) Shell invoked to run file: /etc/rc Command: hostname uClinux Command: mount -t proc proc /proc Command: mount -t sysfs sysfs /sys Command: mount -t usbfs none /proc/bus/usb Command: mkdir /var/tmpusb 1-2: new full speed USB device using isp1362-hcd and address 2 Command: mkdir /var/log Command: mkdir /var/run Command: mkdir /var/lock Command: mkdir /var/empty Command: ifconfig lo 127.0.0.1 Command: route add -net 127.0.0.0 netmask 255.0.0.0 lo Command: cat /etc/motd Welcome to ____ _ _ / __| ||_| _ _| | | | _ ____ _ _ _ _ | | | | | | || | _ \| | | |\ \/ / | |_| | |__| || | | | | |_| |/ | ___\____|_||_|_| |_|\____|\_/\_/ | | |_| For further information check: http://www.uclinux.org/ (http://www.uclinux.org/) Execution Finished, Exiting Sash command shell (version 1.1.1) /> usb 1-2: device not accepting address 2, error -110 usb 1-2: new full speed USB device using isp1362-hcd and address 3 usb 1-2: device descriptor read/64, error -71 usb 1-2: device descriptor read/64, error 8 usb 1-2: new full speed USB device using isp1362-hcd and address 4 usb 1-2: device not accepting address 4, error -110 usb 1-2: new full speed USB device using isp1362-hcd and address 5 usb 1-2: Product: TS128MJFLASHA usb 1-2: configuration# 1 chosen from 1 choice scsi0 : SCSI emulation for USB Mass Storage devices Vendor: Model: TS128MJFLASHA Rev: 1.00 Type: Direct-Access ANSI SCSI revision: 02 /> inetd & [22] /> netstat -a Active Internet connections (servers and established) Proto Recv-Q Send-Q Local Address Foreign Address State tcp 0 0 *:ftp *:* LISTEN tcp 0 0 *:telnet *:* LISTEN Active UNIX domain sockets (servers and established) Proto RefCnt Flags Type State I-Node Path /> fdisk -l /dev/sda /> mount -t vfat /dev/sda1 /mnt mount: Mounting /dev/sda1 on /mnt failed: No such device or address /> It can not mount USB device. I had been tryed every times. Please, help me. Regards faye7 Replies
did you enable scsi disk support in kernel config?
--- Quote Start --- originally posted by hippo@Nov 9 2006, 03:47 AM did you enable scsi disk support in kernel config?<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19324)
--- quote end ---
--- Quote End --- Hi, hippo I enabled scsi disk support in kernel config. It's work without problem.http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Thank you very much. (1)I used thumb USB testing the "UsbHost" (USB ISP1362 driver) it is can be able to access,so it is ok. (2)I used Linux PC testing the "USB Wireless Dongle" (GW-US54GZL driver) it is ok. next, I try out again porting "Wireless Dongle". Regards faye
TO_BE_DONE
Please disable DM9000, and check again.
--- Quote Start --- originally posted by hippo@Nov 9 2006, 10:27 AM please disable dm9000, and check again.<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19343)
--- quote end ---
--- Quote End --- Hi, hippo I disabled DM9000 and try out again, but it is the some problem. "GW-US54GZL_linux_v2.15.0.0_CE.diff.gz" have support zd1211b ? ------------------------------------------------ Welcome To Altera SOPC Builder Version 6.0, Built Mon Apr 24 15:26:45 PDT 2006 ------------------------------------------------ ------------------------------------------------ Welcome to the Nios II Embedded Design Suite Version 6.0, Built Fri Apr 21 04:12:54 PDT 2006 Example designs can be found in /cygdrive/c/altera/kits/nios2_60/examples ------------------------------------------------ (You may add a startup script: c:/altera/kits/nios2_60/user.bashrc) /cygdrive/c/altera/kits/nios2_60/examples [SOPC Builder]$ cd c: /cygdrive/c [SOPC Builder]$ nios2-download -g zImage Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloaded 1775KB in 22.7s (78.1KB/s) Verified OK Starting processor at address 0x00500000 /cygdrive/c [SOPC Builder]$ nios2-terminal nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Uncompressing Linux... Ok, booting the kernel. Linux version 2.6.17-uc1 (faye@localhost) (gcc version 3.4.6)# 17 PREEMPT Fri No v 10 03:26:56 Local time zone must be set--see uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: PID hash table entries: 64 (order: 6, 256 bytes) Dentry cache hash table entries: 1024 (order: 0, 4096 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 5300k/8192k RAM, 0k/0k ROM (1523k kernel code, 1277k data) Mount-cache hash table entries: 512 NET: Registered protocol family 16 SCSI subsystem initialized usbcore: registered new driver usbfs usbcore: registered new driver hub NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 1024 (order: 0, 4096 bytes) TCP bind hash table entries: 1024 (order: 0, 4096 bytes) TCP: Hash tables configured (established 1024 bind 1024) TCP reno registered io scheduler noop registered io scheduler deadline registered (default) Serial: JTAG UART driver $Revision: 1.1 $ ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart usbmon: debugfs is not available driver isp1362-hcd, 2005-04-04 isp1362-hcd isp1362-hcd: ISP1362 Host Controller isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1 isp1362_hc_reset: Clock not ready after 20ms isp1362-hcd isp1362-hcd: irq 4, io mem 0x80900080 isp1362_hc_start: isp1362-hcd isp1362-hcd: ISP1362 Memory usage: isp1362-hcd isp1362-hcd: ISTL: 2 * 256: 512 @ $0000:$0100 isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8): 1152 @ $0200 isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8): 2304 @ $0680 isp1362-hcd isp1362-hcd: USED/FREE: 3968 128 usb usb1: Product: ISP1362 Host Controller usb usb1: Manufacturer: uClinux 2.6.17-uc1 isp1362-hcd usb usb1: SerialNumber: isp1362-hcd usb usb1: configuration# 1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected ISP1362 Host Controller, irq 4 Initializing USB Mass Storage driver... usbcore: registered new driver usb-storage USB Mass Storage support registered. TCP bic registered NET: Registered protocol family 1 NET: Registered protocol family 17 Freeing unused kernel memory: 1052k freed (0x1a8000 - 0x2ae000) Shell invoked to run file: /etc/rc Command: hostname uClinux Command: mount -t proc proc /proc Command: mount -t sysfs sysfs /sys Command: mount -t usbfs none /proc/bus/usb Command: mkdir /var/tmp Command: mkdir /var/log usb 1-2: new full speed USB device using isp1362-hcd and address 2 Command: mkdir /var/run Command: mkdir /var/lock Command: mkdir /var/empty Command: ifconfig lo 127.0.0.1 Command: route add -net 127.0.0.0 netmask 255.0.0.0 lousb 1-2: Product: GW-US54G ZL(TW) usb 1-2: Manufacturer: PCI Command: cat /etc/motd usb 1-2: configuration# 1 chosen from 1 choice Welcome to ____ _ _ / __| ||_| _ _| | | | _ ____ _ _ _ _ | | | | | | || | _ \| | | |\ \/ / | |_| | |__| || | | | | |_| |/ | ___\____|_||_|_| |_|\____|\_/\_/ | | |_| For further information check: http://www.uclinux.org/ (http://www.uclinux.org/) Execution Finished, Exiting Sash command shell (version 1.1.1) /> inetd & [19] /> netstat -a Active Internet connections (servers and established) Proto Recv-Q Send-Q Local Address Foreign Address State tcp 0 0 *:ftp *:* LISTEN tcp 0 0 *:telnet *:* LISTEN Active UNIX domain sockets (servers and established) Proto RefCnt Flags Type State I-Node Path /> modprobe zd1211b _____ ____ _ ____ |__ / _| _ \ / \ / ___| / / | | | | | |/ _ \ \___ / /| |_| | |_| / ___ \ ___) | /____\__, |____/_/ \_\____/ |___/ ZD1211B - version 2.15.0.0 vendor_id = 0053 product_id = 5301 USB 1.1 Host Release Ver = 4810 EEPORM Ver = 4810 Finsih download Firmware. Ready to reboot PA type: 0 PHYNEWLayout = 1 Airoha AL2230S_RF AllowedChannel = 000107ff Region:16 usbcore: registered new driver zd1211b /> ifconfig eth0 up /> iwconfig lo no wireless extensions. Warning: Driver for device eth0 has been compiled with version 20 of Wireless Extension, while this program is using version 17. Some things may be broken... eth0 802.11b/g NIC ESSID:"" Mode:Managed Frequency:2.462GHz Access Point: 00:00:00:00:00:00 Bit Rate:1Mb/s Retry:off RTS thr=9999 B Fragment thr:off Encryption key:off Power Management:off /> iwlist eth0 scan eth0 No scan results Regards faye
The zd1211/b drivers should be OK. I had tested them on PC and my nios2 board with a EHCI usb host.
Maybe it is the isp1362-hcd's problem. I will test them with isp1761. - Altera_Forum
--- Quote Start --- originally posted by hippo@Nov 10 2006, 11:30 AM the zd1211/b drivers should be ok. i had tested them on pc and my nios2 board with a ehci usb host.maybe it is the isp1362-hcd's problem. i will test them with isp1761.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19364)
--- quote end ---
--- Quote End --- Hi , hippo I used DE2 board to creating a project , it USB device is ISP1362. @@ Can you help me solve this problem? ~"~ I am new hand for Nios. I don't know how to solve it. Orz Please, help me. Regards faye
