19 years agoUSbHost have some problem!
Hi,everybody I used uClinux-dist-2006-08-03 dist and DE2 board. I following "Wiki home's UsbHost" steps and enabled "fdisk" and "mount" on busybox. desplay following message: ...
19 years ago --- Quote Start --- originally posted by hippo@Nov 9 2006, 10:27 AM please disable dm9000, and check again.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19343)
--- quote end ---
--- Quote End --- Hi, hippo I disabled DM9000 and try out again, but it is the some problem. "GW-US54GZL_linux_v2.15.0.0_CE.diff.gz" have support zd1211b ? ------------------------------------------------ Welcome To Altera SOPC Builder Version 6.0, Built Mon Apr 24 15:26:45 PDT 2006 ------------------------------------------------ ------------------------------------------------ Welcome to the Nios II Embedded Design Suite Version 6.0, Built Fri Apr 21 04:12:54 PDT 2006 Example designs can be found in /cygdrive/c/altera/kits/nios2_60/examples ------------------------------------------------ (You may add a startup script: c:/altera/kits/nios2_60/user.bashrc) /cygdrive/c/altera/kits/nios2_60/examples [SOPC Builder]$ cd c: /cygdrive/c [SOPC Builder]$ nios2-download -g zImage Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloaded 1775KB in 22.7s (78.1KB/s) Verified OK Starting processor at address 0x00500000 /cygdrive/c [SOPC Builder]$ nios2-terminal nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) Uncompressing Linux... Ok, booting the kernel. Linux version 2.6.17-uc1 (faye@localhost) (gcc version 3.4.6)# 17 PREEMPT Fri No v 10 03:26:56 Local time zone must be set--see uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: PID hash table entries: 64 (order: 6, 256 bytes) Dentry cache hash table entries: 1024 (order: 0, 4096 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 5300k/8192k RAM, 0k/0k ROM (1523k kernel code, 1277k data) Mount-cache hash table entries: 512 NET: Registered protocol family 16 SCSI subsystem initialized usbcore: registered new driver usbfs usbcore: registered new driver hub NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 1024 (order: 0, 4096 bytes) TCP bind hash table entries: 1024 (order: 0, 4096 bytes) TCP: Hash tables configured (established 1024 bind 1024) TCP reno registered io scheduler noop registered io scheduler deadline registered (default) Serial: JTAG UART driver $Revision: 1.1 $ ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart usbmon: debugfs is not available driver isp1362-hcd, 2005-04-04 isp1362-hcd isp1362-hcd: ISP1362 Host Controller isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1 isp1362_hc_reset: Clock not ready after 20ms isp1362-hcd isp1362-hcd: irq 4, io mem 0x80900080 isp1362_hc_start: isp1362-hcd isp1362-hcd: ISP1362 Memory usage: isp1362-hcd isp1362-hcd: ISTL: 2 * 256: 512 @ $0000:$0100 isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8): 1152 @ $0200 isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8): 2304 @ $0680 isp1362-hcd isp1362-hcd: USED/FREE: 3968 128 usb usb1: Product: ISP1362 Host Controller usb usb1: Manufacturer: uClinux 2.6.17-uc1 isp1362-hcd usb usb1: SerialNumber: isp1362-hcd usb usb1: configuration# 1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected ISP1362 Host Controller, irq 4 Initializing USB Mass Storage driver... usbcore: registered new driver usb-storage USB Mass Storage support registered. TCP bic registered NET: Registered protocol family 1 NET: Registered protocol family 17 Freeing unused kernel memory: 1052k freed (0x1a8000 - 0x2ae000) Shell invoked to run file: /etc/rc Command: hostname uClinux Command: mount -t proc proc /proc Command: mount -t sysfs sysfs /sys Command: mount -t usbfs none /proc/bus/usb Command: mkdir /var/tmp Command: mkdir /var/log usb 1-2: new full speed USB device using isp1362-hcd and address 2 Command: mkdir /var/run Command: mkdir /var/lock Command: mkdir /var/empty Command: ifconfig lo 127.0.0.1 Command: route add -net 127.0.0.0 netmask 255.0.0.0 lousb 1-2: Product: GW-US54G ZL(TW) usb 1-2: Manufacturer: PCI Command: cat /etc/motd usb 1-2: configuration# 1 chosen from 1 choice Welcome to ____ _ _ / __| ||_| _ _| | | | _ ____ _ _ _ _ | | | | | | || | _ \| | | |\ \/ / | |_| | |__| || | | | | |_| |/ | ___\____|_||_|_| |_|\____|\_/\_/ | | |_| For further information check: http://www.uclinux.org/ (http://www.uclinux.org/) Execution Finished, Exiting Sash command shell (version 1.1.1) /> inetd & [19] /> netstat -a Active Internet connections (servers and established) Proto Recv-Q Send-Q Local Address Foreign Address State tcp 0 0 *:ftp *:* LISTEN tcp 0 0 *:telnet *:* LISTEN Active UNIX domain sockets (servers and established) Proto RefCnt Flags Type State I-Node Path /> modprobe zd1211b _____ ____ _ ____ |__ / _| _ \ / \ / ___| / / | | | | | |/ _ \ \___ / /| |_| | |_| / ___ \ ___) | /____\__, |____/_/ \_\____/ |___/ ZD1211B - version 2.15.0.0 vendor_id = 0053 product_id = 5301 USB 1.1 Host Release Ver = 4810 EEPORM Ver = 4810 Finsih download Firmware. Ready to reboot PA type: 0 PHYNEWLayout = 1 Airoha AL2230S_RF AllowedChannel = 000107ff Region:16 usbcore: registered new driver zd1211b /> ifconfig eth0 up /> iwconfig lo no wireless extensions. Warning: Driver for device eth0 has been compiled with version 20 of Wireless Extension, while this program is using version 17. Some things may be broken... eth0 802.11b/g NIC ESSID:"" Mode:Managed Frequency:2.462GHz Access Point: 00:00:00:00:00:00 Bit Rate:1Mb/s Retry:off RTS thr=9999 B Fragment thr:off Encryption key:off Power Management:off /> iwlist eth0 scan eth0 No scan results Regards faye
