19 years agoUSbHost have some problem!
Hi,everybody I used uClinux-dist-2006-08-03 dist and DE2 board. I following "Wiki home's UsbHost" steps and enabled "fdisk" and "mount" on busybox. desplay following message: ...
19 years ago --- Quote Start --- originally posted by hippo@Nov 9 2006, 03:47 AM did you enable scsi disk support in kernel config?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19324)
--- quote end ---
--- Quote End --- Hi, hippo I enabled scsi disk support in kernel config. It's work without problem.http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Thank you very much. (1)I used thumb USB testing the "UsbHost" (USB ISP1362 driver) it is can be able to access,so it is ok. (2)I used Linux PC testing the "USB Wireless Dongle" (GW-US54GZL driver) it is ok. next, I try out again porting "Wireless Dongle". Regards faye
