17 years ago
Updating the nios2-linux-20090825 package
I am running the update script found in the nios2-linux directory and, among other things, it appears to be updating the tools in toolchain-mmu/x86-linux2/bin but renaming them in the process. Should I use this script to update this distro or should I just use git for updates?
Thanks ahead!
    use the script, it just calls git. the toolchain naming update is expected.
    I thought everything was working properly with the update script but now, my CROSS_COMPILE is still pointing to nios2-wrs-linux-gnu. Where can I change this?
    Please try pull in the uClinux-dist directly.
    cd uClinux-dist
    git pull origin trunk
    Then check if you have the correct vendors/config/nios2/config.arch line 18.
    - Hippo
