17 years agoUpdating the nios2-linux-20090825 package
I am running the update script found in the nios2-linux directory and, among other things, it appears to be updating the tools in toolchain-mmu/x86-linux2/bin but renaming them in the process. Should...
17 years agoPlease try pull in the uClinux-dist directly.
cd uClinux-dist git pull origin trunk Then check if you have the correct vendors/config/nios2/config.arch line 18. - Hippo
