19 years agouClinux port to Stratix IIEP2S60
Had some projects implemented in Stratix IIEP2S60, on Stratix Dev. kit and stand alone FPGA also.
Need Ethernet or USB and some good linux benefits. So started thinking about applying Linux. But so many topics read are all about Cyclone and Nios II dev. kit. Simple question, is uClinux good and ready for all Altera's SoPC? Or theoretically saying, good for any system based on Nios II, but some need to wait for Kernel support patchs? Thanks4 Replies
If your boards have more than 8MB SDRAM, they can run uClinux.
It does not matter dev board or custom boards, nor stratix and cyclone. You may follow the wiki. http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux) For eth and usb, if you use PCI then there are a lot of drivers. If you go without PCI, you can use DM9000A or SMC91c111 for eth ISP1761 or ISP1362 for usb. - Altera_Forum
Are you succeed in running uClinux ? if possible, I would like to know which FPGA configuration is used by you (cpu options, TCM, jtag uart or serial uart....etc..). Thanks in advance.
<div class='quotetop'>QUOTE (hippo @ Mar 20 2007, 07:23 AM) <{post_snapback}> (index.php?act=findpost&pid=22352)</div>
--- Quote Start --- If your boards have more than 8MB SDRAM, they can run uClinux. It does not matter dev board or custom boards, nor stratix and cyclone. You may follow the wiki. http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux) For eth and usb, if you use PCI then there are a lot of drivers. If you go without PCI, you can use DM9000A or SMC91c111 for eth ISP1761 or ISP1362 for usb.[/b] --- Quote End --- hi friend, i want to access dm9000a can u tell me the flow - Altera_Forum
<div class='quotetop'>QUOTE (campo85 @ Jun 22 2009, 12:39 PM) <{post_snapback}> (index.php?act=findpost&pid=22876)</div>
--- Quote Start --- Are you succeed in running uClinux ? if possible, I would like to know which FPGA configuration is used by you (cpu options, TCM, jtag uart or serial uart....etc..). Thanks in advance.[/b] --- Quote End --- hi friend, i want to access dm9000a can u tell me the flow
