19 years agouClinux port to Stratix IIEP2S60
Had some projects implemented in Stratix IIEP2S60, on Stratix Dev. kit and stand alone FPGA also. Need Ethernet or USB and some good linux benefits. So started thinking about applying Linux. ...
17 years ago<div class='quotetop'>QUOTE (campo85 @ Jun 22 2009, 12:39 PM) <{post_snapback}> (index.php?act=findpost&pid=22876)</div>
--- Quote Start --- Are you succeed in running uClinux ? if possible, I would like to know which FPGA configuration is used by you (cpu options, TCM, jtag uart or serial uart....etc..). Thanks in advance.[/b] --- Quote End --- hi friend, i want to access dm9000a can u tell me the flow
