19 years agouClinux port to Stratix IIEP2S60
Had some projects implemented in Stratix IIEP2S60, on Stratix Dev. kit and stand alone FPGA also. Need Ethernet or USB and some good linux benefits. So started thinking about applying Linux. ...
19 years agoIf your boards have more than 8MB SDRAM, they can run uClinux.
It does not matter dev board or custom boards, nor stratix and cyclone. You may follow the wiki. http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux) For eth and usb, if you use PCI then there are a lot of drivers. If you go without PCI, you can use DM9000A or SMC91c111 for eth ISP1761 or ISP1362 for usb.
