16 years agouClinux-dist-20100315 make vendor_hwselect
hi,everyone!
i am using "uclinux-dist-20100315.tar.bz2"downloaded fromhttp://www.uclinux.org/pub/uclinux/dist/ (http://www.uclinux.org/pub/uclinux/dist/).i build my niosii system in sopcbuilder named niosii.when i do the follow step: make vendor_hwselect sysptf=/usr/local/src/niosii.ptf the result is as follow: [root@localhost uClinux-dist]# make vendor_hwselect SYSPTF=/usr/local/src/niosii.ptf make ARCH=nios2nommu -C vendors vendor_hwselect make[1]: Entering directory `/usr/local/src/uClinux-dist/vendors' make -C /usr/local/src/uClinux-dist/vendors/Altera/nios2nommu/. dir_v=/usr/local/src/uClinux-dist/vendors/Altera/nios2nommu/. -f /usr/local/src/uClinux-dist/vendors/vendors-common.mak vendor_hwselect make[2]: Entering directory `/usr/local/src/uClinux-dist/vendors/Altera/nios2nommu' [ -d /usr/local/src/uClinux-dist/romfs/$i ] || mkdir -p /usr/local/src/uClinux-dist/romfs make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -C /usr/local/src/uClinux-dist/linux-2.6.x hwselect no emulation specific options. make[3]: Entering directory `/usr/local/src/uClinux-dist/linux-2.6.x' no emulation specific options. scripts/kconfig/conf -s arch/nios2nommu/Kconfig * * Restart config... * * * RCU Subsystem * RCU Implementation > 1. Tree-based hierarchical RCU (TREE_RCU) (NEW) 2. Preemptable tree-based hierarchical RCU (TREE_PREEMPT_RCU) (NEW) 3. UP-only small-memory-footprint RCU (TINY_RCU) (NEW) choice[1-3]: is it the right result?but i don't know how to keep on for there are so many needed to confige no matter i chose 1 or 2 or 3. i wonder if the choice of cpu ,sramand sdram followed the "rcu implementation"?thank you very much!4 Replies
Did you run make menuconfig first?
--- Quote Start --- Did you run make menuconfig first? --- Quote End --- thank you for your reply !yes,i make munuconfig as follow: Vendor/Product Selection ---> --- Select the Vendor you wish to target Vendor (Altera) ---> --- Select the Product you wish to target Altera Products (nios2) ---> Kernel/Library/Defaults Selection ---> --- Kernel is linux-2.6.x Libc Version (None) ---> [*] Default all settings (lose changes) [ ] Customize Kernel Settings [ ] Customize Vendor/User Settings [ ] Update Default Vendor Settings then make vendor_hwselect sysptf=/usr/local/src/niosii.ptf. there are so many things to be customed.why? - Altera_Forum
--- Quote Start --- there are so many things to be customed.why? --- Quote End --- This is embedded Linux. -Michael - Altera_Forum
--- Quote Start --- This is embedded Linux. -Michael --- Quote End --- But as a green figure,when "make menuconfig",I left almost everything default as follow: Kernel Version (linux-2.6.x) ---> Libc Version (None) ---> glibc Library Configuration (if selected) ---> [*] Default all settings (lose changes) [ ] Customize Kernel Settings [ ] Customize Application/Library Settings [ ] Update Default Vendor Settings There should be not so many things to be customed , isn't it?
